Thanks for the info, interesting.
What was the result of the main loop LED flash when running on HSE (crystal)?
EXTI Interrupt Issue on STM32
LeighM
- Has thanked: 110 times
- Been thanked: 302 times
liudeqiang_2008
- Has thanked: 11 times
- Been thanked: 2 times
Re: EXTI Interrupt Issue on STM32
The main loop LED flash running ok with HSE.
Br, Deqiang
- Flowcode1-3.fcfx
- (16.09 KiB) Downloaded 461 times
- (view online)
LeighM
Thanks. So, just to confirm what I think you are reporting, with your latest program...
running on HSE...
The main loop flash (1 second on, 1 second off) runs OK, even when the hardware is power cycled.
But the timer interrupt flash often runs much slower when power cycled, but runs OK following program flash and run.
running on HSI...
All works as expected, on reset and on power cycle.
Thanks for your reply, it helps narrow down the possible scenarios.
Might be worth try adding a delay at the start of main, before the interrupt setup?
running on HSE...
running on HSI...
liudeqiang_2008
Yes, what you summed is corect.LeighM wrote: ↑Thu Aug 14, 2025 10:46 amThanks. So, just to confirm what I think you are reporting, with your latest program...
running on HSE...
running on HSI...
For your suggestion, I have add the delay:
1, 10ms before all the interrupts
2, 50ms before all the interrupts
3,100ms before all the interrupts
4,100ms before each the interrupts
Looks no different. it didn't help.
Br, Deqiang
- 屏幕截图 2025-08-16 113626.png (209.88 KiB) Viewed 8236 times
- Flowcode1-4.fcfx
- (16.42 KiB) Downloaded 584 times
- (view online)
LeighM
Thanks for the feedback.
Although I can't see what the problem might be, especially if the main loop LED flash is correct in all cases, which implies that the system clock is setup OK and running as expected.
Why the timer interrupt should differ between using HSE and HSI as a source is eluding me at the moment.
I was initially suspecting crystal startup or crystal frequency issues.
btw. The maximum clock rate for APB1, as used by these timers, is 36MHz, but you do seem to have set that correctly in the config.
Maybe it's worth a test at /4 just to see if that improves things?
Could you provide further information on the hardware used?
I don't have any F3 hardware (I've done numerous projects with F4)
Hopefully Matrix, or others, have an F3 development board and some available time to see if they can replicate the issue?
liudeqiang_2008
What type of F4 MCU you are using the most, perhaps I'd better gave up F3, and move to F4 , there is too much small bugs on F3 support...LeighM wrote: ↑Sat Aug 16, 2025 5:20 pmThanks for the feedback.
Thank you
Br, Deqiang
LeighM
I'm not using anything at the moment
Despite retirement, I don't seem to have much spare time.
I've used 205/405 in the past, but don't have any of that hardware now.
So I wouldn't let that sway you.
btw. Did you do any tests at a lower APB1 timer clock speed?
I did wonder if you are getting erratic behavior due to being at the max edge.
liudeqiang_2008
HelloLeighM wrote: ↑Wed Aug 20, 2025 3:26 pmI'm not using anything at the momentDespite retirement, I don't seem to have much spare time.
I have tested with 36MHz on APB1, the result is the same, this is not the reason.
Br, Deqiang
LeighM
I've bought an STM32F303 development board to play with.
I've not had any issues with the timer interrupt.
However, my testing has thrown up an issue with the 32F303CB FCD, the config section is missing the HSE source divider parameter.
This means it would be easy to accidentally overclock the device.
I've attached an updated FCD that goes into directory C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ARM if you want to give this a test. This FCD adds the HSE divider.
If you use this FCD with your existing projects you will need to carefully reset all the config parameters (as the old parameter/value pairs will be out of step).
If you now compare running HSI versus HSE, I suggest you set the HSE source divider to /2, that will then mean HSI and HSE settings will be equivalent.
If all goes well Matrix can merge this change back into the repo.
liudeqiang_2008
Hi my dear friend!LeighM wrote: ↑Sat Aug 30, 2025 3:52 pmHi,
32F303CB.fcdx
Sorry for late reply. I was out of office during last week.
I have download your fcdx file and replace it. and set the HSE source divider to /2 as what you mentioned. the final HCLK is 64 MHz.
It works fine!! Also works after restart or power off and on.
So it means what you found about the issue was correct!
Thank you very much, hope this issue can be fixed about other related chips.
Best regards,
Deqiang
- 屏幕截图 2025-09-08 204706.png (195.17 KiB) Viewed 5732 times
