Unable to create microcontroller ARD.ATMEGA.BL0055 - definition file missing or corrupt
andeug
Has thanked: 40 times
Been thanked: 6 times
Post by andeug »
I am getting a strange error on Windows 11 after installing Flowcode and I don't know how to fix this:
"Unable to create microcontroller ARD.ATMEGA.BL0055 as the definition file ARD.ATMEGA.BL0055.FCD is missing or corrupt."
The error appears immediately after I start FC and trying to select the template "Arduino (BL0055) + Combo (BL0114)" with the two Eblocks2 boards which I own.
Andreas
Screenshot 2025-05-23 220022.png (15.48 KiB) Viewed 6956 times
andeug
Re: Unable to create microcontroller ARD.ATMEGA.BL0055 - definition file missing or corrupt
Post by andeug »
I get exactly the same error when I am trying to open the file called "Arduino (BL0055) + Combo (BL0114).fcfx", which is located on C:\Program Files (x86)\Flowcode v10\DefaultData\FlowcodeV10\Misc\Templates\E-Blocks 2
Screenshot 2025-05-24 125443.png (155.7 KiB) Viewed 6928 times
Any of those upper files are opening without any error, and it's only the Arduino (BL0055) + Combo (BL0114) that gives me the error.
I uninstalled Flowcode and its drivers a few times and got the same window regarding ARD.ATMEGA.BL0055.fcd file missing or corrupt. I was not able to locate this file on my computer neither, so it's probably missing.
Can someone please share its content and location, so that I can add it to my installation and try to see if it works?
Has thanked: 478 times
Been thanked: 713 times
Post by chipfryer27 »
Problem appears to be with the latest BL0055 update.
I created a simple chart with both the 55' and combo board, saved and could open without issue. Flowcode informed of an update to the 55' and I downloaded. This caused problems similar to yours.
Rolling back the BL0055 to v3 solved the problem.
Screenshot 2025-05-24 063151.jpg (16.01 KiB) Viewed 6919 times
If you roll back until Matrix resolve the issue you should be good.
Has thanked: 794 times
Been thanked: 853 times
Many thanks for reporting this.
We will have an update as soon as we can.
out of curiosity ,so you still have the same issue, or is it resolved now?
Hi Martin
I'm travelling just now so can't check on any HW.
andeug
Post by andeug »
medelec35 wrote: ↑
Thu Aug 28, 2025 10:58 am
If it's me you're asking, then my problem was solved. Meanwhile, I have purchased a DELL Optiplex desktop PC, as I was struggling with some compatibility issues on the Win11 virtual machine, which was hosted on a Parallels Desktop for Mac instance. One of the problems which I still encounter there is that I cannot install the Matrix TSL USB drivers for E-Blocks2.
