Hi, when I fill it out, it gives me an error.
I'm attaching the error file.
Thanks.
STM32F411 COMPILER ERROR
max.tisc
- Been thanked: 12 times
Re: STM32F411 COMPILER ERROR
Hi, can anyone help me? It was working fine before.
It doesn't even work on FC9 and it used to work here too
Thanks.
Thanks.
- Has thanked: 794 times
- Been thanked: 858 times
When Flowcode users have a compile error, It helps if they can attach .fcfx, .msg.txt and .c files.
As you have only attached .msg.txt, we are unable to to help.
ok sorry
the files are attached
thank
thank
- led.msg.txt
- (2.66 KiB) Downloaded 252 times
- led.fcfx
- (9.29 KiB) Downloaded 253 times
- (view online)
- led.c
- (6.05 KiB) Downloaded 260 times
- Has thanked: 478 times
- Been thanked: 713 times
Compiles to C and Hex OK for me. I don't have the chip to try HW though.
Are all your components up to date and toolchain paths correct?
I fully agree with chipfryer27.
In addition to his comments, your .fcfx file compiles for me with no issues.
Looking at your .msg.txt it appears you have saved your .fcfx file on dropbox.
That could be your issue.
Rather than saving to dropbox you could just try saving .fcfx project file in a directory on your C drive.
Further to Martin above
I hadn't noticed "Dropbox" which has in the past caused issues for me (and others that were not local). I've also had issues with spaces in the file name but offhand I can't remember what I was compiling too.
These are current component versions and my locations, if it helps.
Hi, thanks everyone for your support.
I've always used Dropbox. The files are in a folder on my PC and then updated on Dropbox, and it's never given me any problems. I put the LED file in another folder on C, but I get the same error. Now I've downloaded FC10 to a laptop connected to Dropbox, and the compilation works. I'm attaching a screenshot of how it's set up on my desktop PC.
- Screenshot 2025-09-17 180134.png (44.26 KiB) Viewed 5065 times
- Screenshot 2025-09-17 180233.png (64.09 KiB) Viewed 5065 times
