ADS1115
Has thanked: 246 times
Been thanked: 258 times
ADS1115
Hi to All
The ADS1115 is working fine in "single" input mode.
Also the device addresses and the gain-set is perfect.
It is easy to use, for example, four ADS115s on an I2C bus.
There are small problems
Can this be improved?
If the alert pin is not connected, a message appears befor compile.
Setting samples per second.
A positiong is missing. The 32 per second.
I wanted to look in the component source code, but it is not available.
Has thanked: 647 times
Been thanked: 856 times
Re: ADS1115
Hi Stefan,
Thanks for letting us know.
I've pushed an update for you to hopefully address the problems you've mentioned.
Re: ADS1115
The 32 SPS is fixed.
The alert pin is fixed.
I wrote a simple program "post_ADS1115_1" and its perfect.
In my Program was an additional old pin I have to delet...
