Flowcode Target Devices Spreadsheet
Has thanked: 800 times
Been thanked: 865 times
I have created a spread sheet that allows you to filter the ideal Target Device.
It contains all the target devices except for any target device that was created this year.
1st select the Pack filter e.g. just have PIC8 devices.
Then you can select filters in order of important requirements.
E.g. max ADCs, ROM or RAM etc.
You will then be left with a device list.
Or you can just search for a device and you will see the specs for it.
A tip unselect all before choosing filter value.
Edit: Spreadsheet updated see below.
Flowcode Target Devices.xlsx
(134.48 KiB) Downloaded 672 times
Has thanked: 478 times
Been thanked: 713 times
Re: Flowcode Target Devices Spreadsheet
Post by chipfryer27 »
Hi Martin
Just had a play and it works well :)
Thanks Iain.
Just a couple of minor improvements.
Added Notes column all formatted to wrap, just in case.
If you make lots of notes you can filter them out them as well.
Added Devices Left to help you decide if to select more filters or narrow down any filter selection.
Flowcode Target Devices v1.01.xlsx
(135.78 KiB) Downloaded 585 times
