PIC16F15313 ADC AN5
bitbita
PIC16F15313 ADC AN5
Post by bitbita »
Hello! I can't select channel AN5 in the PIC16F15313 ADC component settings, even though the microcontroller documentation lists this channel. How can I solve this problem?
Has thanked: 795 times
Been thanked: 858 times
Flowcode v11 Re: PIC16F15313 ADC AN5
Many thanks for the bug report, I have replicated the issue.
Since you have not used a 10 or 11 post icon, I will assume you are using Flowcode V11
If you browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
%ProgramData%\MatrixTSL\FlowcodeV11\FCD\PIC\
Replace the original file with the attached version.
If Flowcode is already open, then you will need to reload your project.
If you run any component updates, then the fcdx you added will be overwritten.
16F15313.fcdx
(27.34 KiB) Downloaded 216 times
bitbita
Post by bitbita »
Thanks for your help! Everything worked out!
Has thanked: 647 times
Been thanked: 856 times
Many thanks,
This issue has now been resolved in the library update system for v10 and v11.
