Reading sw version loaded on Arduino
kramtlas
Has thanked: 7 times
Been thanked: 2 times
Post by kramtlas »
Is it possible to read back the sw version loaded onto an arduino?
I have an arduino that I coded some time ago to control a window circuit but, since then there have been several iterations
of this code i.e. WindowControl_1.fcfx, WndowControl_2.fcfx etc. and I would like to find out what is currently loaded if possible.
Has thanked: 177 times
Been thanked: 1026 times
Re: Reading sw version loaded on Arduino
Post by mnfisher »
Assuming you didn't set the lock bits - you can read the contents of flash using avrdude.
avrdude -p atmega328p -c arduino -P <Your_Port> -b 115200 -U flash:r:arduino_flash_dump.hex:i
Then look through the hex looking for your version string .. "v1.2345 11/23" of you are lucky...
Has thanked: 647 times
Been thanked: 856 times
There's a component available under Storage called Auto Version ID which gives you the build number and the date/time of your build.
You would still have to display this information or output it on a UART etc but it provides a nice easy way to manage firmware versions.
