Hi, I wanted to ask if the internal RTC component can read and write to the STM32f411's RTC. That would be great, so I don't have to add any other components to get an RTC.
Thanks.
BLACKPILL STM32F411 RTC
max.tisc
- Been thanked: 12 times
- Has thanked: 616 times
- Been thanked: 814 times
Re: BLACKPILL STM32F411 RTC
Thanks for your question.
I've checked and it looks like the internal RTC should be supported already for that device.
Let us know if you have any problems.
I made this simple code to test, but it doesn't work and everything is frozen; the LED isn't even blinking. I think I understand that RTC must be enabled in the configuration, and I didn't see it in the oscillator settings screen. It seems that RTC is disabled by default. I'm attaching a screenshot of the affected part that's enabled.
- Screenshot MOD.png (156.13 KiB) Viewed 5875 times
- RTC_STM32F411_FC10.fcfx
- (15.62 KiB) Downloaded 315 times
Hi leightM
Yes, I remembered the issue and tried to replicate it, but it doesn't work unless I have to reload STARM_CAL_RTC.c. Should it already be up to date with the various updates released subsequently, or not?
LeighM
- Has thanked: 103 times
- Been thanked: 302 times
I just done a full update (V10), the CAL file is up to date, and includes the RTC enable code.
I've successfully compiled your test program and it runs fine on my Blackpill, LED flash, no lockup and UART output OK.
I also added a read and output of RTC seconds, which do increment.
Hope that helps.
Hope that helps.
LeighM
Update...
Ah, my previous post might not be true..
The Full Update doesn't seem to check all files.
I'm running on the STARM_CAL_RTC.c from the "STM32F QUESTIONS" thread.
Even if I delete it, Flowcode doesn't seem to detect this and update it, so I can't check what's in the Matrix repo.
Ben, is this fixable?
Thanks!
Thanks!
I reloaded the STARM_CAL_RTC.c file but it didn't work. Did you have to change the project options settings to get it to work?
LeighM
No, I didn't change any settings.
Have you tried a power cycle of the board after the updated build is transferred?
If it still locks up, maybe my working version is due to some previously run code?
I think all the C code I've tried/run is posted on that previous post/thread
tried different configurations, turning it off and on again but it always blocked
