3663: LCDDCPIN = FCL_DC;
(192) undefined identifier "LCDDCPIN"
Error from XC8
Component LCD_ST7789V and PIC18F26k22
JAGagiano
- Has thanked: 800 times
- Been thanked: 866 times
Re: Component LCD_ST7789V and PIC18F26k22
That is suggesting that within properties you have not assigned any pina to the LCD DC connection.
If you have assigned all the pins and still got an error then can you upload the fcfx, and msg.txt files.
Hi Martin
Yes, I have setup all the pins correctly.
After compiling the message appear. Most likely from XC8.
When I look at the C code , I do not see the DC pin assigned to any port.
Hi Martin
You will see that after compiling the message from XC8.
- LCD test.msg.txt
- (2.7 KiB) Downloaded 466 times
- LCD test.fcfx
- (18.27 KiB) Downloaded 415 times
- (view online)
- Has thanked: 650 times
- Been thanked: 856 times
Many thanks for letting us know, Looks like at some point we renamed A0 Pin to DC Pin and this has caused the compile error.
All fixed now in v10 and v11 via the library updates..
First test and it compiled correct.
Had my SPI on the wrong port.
Correct the port and it did not compile.
Get the following message.
Copyright (C) 2019 Microchip Technology Inc.
(908) exit status = -1073741819
(908) exit status = 1
Please can you attach your project file that's doing this and I'll look into it for you.
