MQTT_Client
minolta
Has thanked: 1 time
MQTT_Client
Post by minolta »
When i try to use MQTT Client, i have the bellow compiler error:
../main/esp-project.c: In function 'FCD_0a9d1_MQTT_Client1__Disconnect':
../main/esp-project.c:1110:9: error: 'FCR_RETVAL' may be used uninitialized in this function [-Werror=maybe-uninitialized]
cc1.exe: some warnings being treated as errors
[13/45] Linking CXX static library esp-idf\esp_ringbuf\libesp_ringbuf.a
Running ninja in directory d:\esp32_test\mqtt\flowcode1\build
Executing "ninja all"...
ninja failed with exit code 1
Build Failed
Any ideas?
Tiberiu
Flowcode1.fcfx
(8.84 KiB) Downloaded 661 times
Flowcode1.msg.txt
(23.44 KiB) Downloaded 693 times
minolta
Has thanked: 1 time
Re: MQTT_Client
Post by minolta »
In the mean time i use "IoT Made Easy" library.
Now, from Node Red to ESP32, via MQTT i can send and receive data without any compile error.
Tiberiu
Has thanked: 616 times
Been thanked: 814 times
Re: MQTT_Client
Many thanks for letting us know. I have now fixed the error with the MQTT component on the ESP32 hardware.
minolta
Has thanked: 1 time
Re: MQTT_Client
Post by minolta »
Thanks, i will check it in the following days.
Tiberiu
minolta
Has thanked: 1 time
Re: MQTT_Client
Post by minolta »
Checked, functional.
Many thanks Ben.
