Web App not working on Android
simisv
Has thanked: 5 times
Been thanked: 5 times
Re: Web App not working on Android
Post by simisv »
No matter what I do changing settings and installing different web browsers still no data is sent from my phone .
There are people using webapps that really work on android phones ?
simisv
Post by simisv »
I have an update
If I type the command in the address bar of Chrome, 192.168.0.244:8080/aoff , a pop up window appears telling me that this address doesn't support a secure connection with HTTPS and it will give me two options, Go Back or Continue.
If I choose Continue then the command is being sent and the page will display the answer sent from ESP32.
This conclude that the communication between phone ( Chrome browser) and ESP32 are working. The problem must be in the WebApp code and I have no idea where.
simisv
Post by simisv »
Just tried TrebEdid html editor from Google Play.
Running the page from this app all commands are working ok .
TrebEdit is the only app so far that can run the WebApp without problems.
Still don't know how to solve the web browser issues.
Has thanked: 478 times
Been thanked: 713 times
Post by chipfryer27 »
Most browsers now have HTTPS as default, and offhand I think there is a way to construct your request to use insecure, but I need to go look at previous projects to refresh myself.
Glad to hear you are progressing though.
From memory I think Chrome has a setting under Privacy/security, well somewhere, that tells it to allow http:
As I am in the pub enjoying well needed beer my memory might not be reliable :)
simisv
Post by simisv »
I think Chrome is a lost cause, for now at least.
I did a fresh install of Samsung Web Browser, I changed the default web browser inside phone settings for main apps , saved the webapp html file on google drive and set the file to be available offline, then created a shortcut to home screen and next to it a shortcut for Samsung browser app .
Unfortunately when I open the file , will display the web page and doesn't send any data , then I click the 3 dots on the right corner and select "Open with" = Samsung browser and Shock.... everything works !!! And Samsung browser can access the file next time when I open it. Next time just open the Samsung browser and the WebApp will be open by default.
Finally I found out how to solve it.
I don't know if there's a simpler solution.
Thanks guys for support.
Happy new year!!!!!!!!
Happy New Year to you too (and everyone else).
Glad to hear you have it working but there must be an easier way than that. When I get a chance I'm going to create an "app" to interact with something on my server and see what happens.
