Hi, trying to use the latest GLCD_RPI component, revision 10.
I can't set the 'Base_GLCD::gLCD_Font1::Font' value.
When I click on the drop down option arrow there are no options presented, just a small empty box, previously I had revision 6 installed and this worked ok.
See screenshot attached for appearance:
GLCD_RPI component bug
rotaxmax55
- Has thanked: 650 times
- Been thanked: 856 times
Re: GLCD_RPI component bug
It seems to be working for me in v10. Can you please try clicking on Help -> Library updates and changing Files in use to Full Database. Download the latest of everything and then close and restart Flowcode and hopefully you will have selectable fonts again for the RPI display.
rotaxmax55
Hi BenR
I tried that but now I am just getting compile errors which I can't decipher: Attached is the source code.
- RPi_Servo_Drive_V10_06012026.fcfx
- (255.33 KiB) Downloaded 358 times
- (view online)
