Device: ARD.ATMEGA.ATMEGA328P
Generated by: Flowcode v9.3.1.36
Date: Thursday, January 08, 2026 12:41:03
Users: 1
Registrado a: volodymyr0604 (85678438)
Clave de licencia:18UBUV
NO DESTINADO A USO COMERCIAL
https://www.flowcode.co.uk
Using <Control_LiFePO4> user settings for compiler
Iniciando el compilador...
C:\Program Files (x86)\Flowcode\Common\Compilers_New\avrv5\batchfiles\avra.bat "C:\Program Files (x86)\Flowcode\Common\Compilers_New\avrv5\atmega328p" "E:\Electronica\PROECTOS\Proba_Arduino__NANO_V3\Controlador_LiFePO4_NANOV3-00.elf" "E:\Electronica\PROECTOS\Proba_Arduino__NANO_V3\Controlador_LiFePO4_NANOV3-00.c" "E:\Electronica\PROECTOS\Proba_Arduino__NANO_V3\Controlador_LiFePO4_NANOV3-00.lst"
E:\Electronica\PROECTOS\Proba_Arduino__NANO_V3>REM CRC: EA277D0C7EF9B4E537B79187D0BE7A25FA6080B4B01BE48BAF713429E4B690411241251B4A05C2B5828F4452C9F7348705C640EF477B79E0C7881D2E5EEC9BD6FE0D8D4660AC0314F98C28BCA92AF856EFD1DB5B777140BC4D00059D7958998291880A09BBE74CF7BA3F4E37F13004EE3637760F1F0B7DA0CC623CD30E3C7D6BAB4C3FE6151D92B8EC0ADD55E96639DAC02472BDE3806EF43AE3A028BD32A5DAE68BB191DA97CB6883A66D3C41849952BB2DD264AF32733E2C3050DA273BE4EEFF12703F3DAF67B119A5A5B069403B38249A6C4D8A1304B09A437E7E2D43FD26DF891DB3086C82D6
E:\Electronica\PROECTOS\Proba_Arduino__NANO_V3>REM REVISION: 1.0
E:\Electronica\PROECTOS\Proba_Arduino__NANO_V3>REM GUID: EA0828B2-5C70-41A5-8C54-F359DD5CC88B
E:\Electronica\PROECTOS\Proba_Arduino__NANO_V3>REM DATE: 29\03\2021
E:\Electronica\PROECTOS\Proba_Arduino__NANO_V3>REM DIR: FCD\AVR\batchfiles\avra.bat
E:\Electronica\PROECTOS\Proba_Arduino__NANO_V3>"C:\Program Files (x86)\Flowcode\Common\Compilers_New\avrv5\atmega328pbin\avr-gcc.exe" -mmcu="E:\Electronica\PROECTOS\Proba_Arduino__NANO_V3\Controlador_LiFePO4_NANOV3-00.elf" -Os -ffunction-sections -fdata-sections -funsigned-char -o "E:\Electronica\PROECTOS\Proba_Arduino__NANO_V3\Controlador_LiFePO4_NANOV3-00.c" "E:\Electronica\PROECTOS\Proba_Arduino__NANO_V3\Controlador_LiFePO4_NANOV3-00.lst" -lm -Wl,-gc-sections
El sistema no puede encontrar la ruta especificada.
Error returned from [avr-gcc.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers_New\avrv5\batchfiles\avra.bat notificado código de error 0x3
Autoclose turned off
FINALIZADO
error compilador arduino ATMEGA328P
volodymyr0604
- Has thanked: 292 times
- Been thanked: 458 times
Re: error compilador arduino ATMEGA328P
Please post the fcfx and msg.txt files as that will help solve the problem.
