PIC16F18345 timing errors
ianjoh
Flowcode v10 PIC16F18345 timing errors
Post by ianjoh »
Hi.
I am having timing errors with this pic on a basic flasher.
It looks to be running at 4x normal speed, I have set the delay to 2 secs to slow the led down enough for me to count the flashes. I am getting 10 flashes per 9 to 10 second time period.
The pic is on an external 4Mhz crystal.
Thanks Ian
16F18345_multisounder_test.fcfx
(7.99 KiB) Downloaded 270 times
Has thanked: 478 times
Been thanked: 713 times
Re: PIC16F18345 timing errors
Post by chipfryer27 »
You have the oscillator set wrong in Project Options.
For External Oscillator Mode between 100KHz and 4MHz you should set at XT
Software Oscillator mode should just be EXTOSC (you have it at 4xPLL which multiplies the clock by a factor of four)
Screenshot 2026-01-10 044318.jpg (41.93 KiB) Viewed 2861 times
Hope this helps.
PS
I moved the post to "General" as this is not a bug.
ianjoh
Post by ianjoh »
Thank you that has sorted it.
Have to put that down to a late night senior moment!
Haha
Done many similar..
Glad it's sorted now.
