Buzzer component
Billduck1302
Has thanked: 2 times
Been thanked: 1 time
Buzzer component
Post by Billduck1302 »
I am using the stock component. To play more than 1 tone, it seems that one has to add the component for each tone.
It would be nice if one could specify the pitch and duration when calling it.
Has thanked: 795 times
Been thanked: 858 times
Re: Buzzer component
That is not how the Buzzer component is intended to work.
The Buzzer component is a single fixed frequency component only sets an output to high or low, depending the buzzer is on or off.
With actual hardware to make it buzz, a fixed DC supply e.g. 9v is used to enable buzzer.
For a buzzer of different frequencies, then a loud speaker, amplifier and PWM will be required.
If less harsh tone, then you could use a DS sine generator.
Has thanked: 647 times
Been thanked: 856 times
The Buzzer component is targetting fixed frequency buzzers, while the simulation outputs a tone the hardware will simply turn an output on and off. Martin beat me to it ;)
I beleive what you're after is the Piezo component which targets a variable frequency device which is much more like a solid state speaker. This requires a audio frequency output to it and has a function "BuzzerOnDelay" which has the two parameters you specified.
Hope this helps.
