The 16f18877 has a Zero Cross Detector as one of its CIP.
I cannot find this component within FC.
Is the ZCD accessed by utilizing the "CODE" command icon within the flow chart?
Or am I missing something?
Did a search within FC and no results.
16f18877 internal Zero Cross Detector
hippalator
- Has thanked: 6 times
- Has thanked: 174 times
- Been thanked: 997 times
Re: 16f18877 internal Zero Cross Detector
Yes, you would need to use some C to enable the ZCD module - this would be in either a code block or in a custom interrupt.
See section 21 of the datasheet.
It looks relatively straightforward - but if using it to measure mains zero crossing then great care is needed with the wiring (not something for a breadboard
The syntax REGISTERbits.FIELD = n (for example ZDCONbits.EN = 1) or REGISTER = n to set the whole register is used.
I wired up a PIC16F18877 to a signal generator and tried the ZCD hardware.
Note - I tested with a 20MHz external crystal - if you have use the internal oscillator at 32MHz you will need to set OSCCON. (I did a blinkie first to test settings correct!)
This very small sample code - I enable the ZCD interrupt handler (in the 'custom' interrupt enable block) setting INTN to enable negative edge interrupts.
The ISR toggles a pin - I used D1 (set in properties) - this is attached to a logic analyser.
I connected the signal to RA0 via a 10K resistor (and I set the signal to be -2.5 to +2.5V) (15K would probably be a better value for this?)
With a 50Hz signal - I get 20ms pulses at RD1.
Note that if I enable the INTP and INTN interrupts - the wave spends more time in one phase - though the total time is still 20ms. This is a result of the pic attempting to 'balance' the input to 0.75V (I guess) rather than 0V
A little testing and a 5kHz signal works AOK (but 10kHz does not!) Results at 32MHz will vary!
- ZCD_Test.fcfx
- (9 KiB) Downloaded 216 times
Something to try:
The ZCD should be capable of much higher speeds than this (although maybe not toggling a pin - which will take quite a few cycles) - try incrementing a counter in the ISR instead of the pin set - then output the count every 1s to a UART (via a FTDI convertor) or a display.
A capacitor between the signal and GND might also be a good idea (|wound the resistor lead around the MCU (in a ZIF socket) pin - which is not a good idea!)
hippalator
Thank you.
20ms would be 50hz.
My reason for implementing the ZCD is triggering.
The idea is to trigger the AD9834 at zero cross over to either increase or decrease, through software, the output phase to hopefully sync the AD9834's output to a signal and track it utilizing the AD9834's pselect pin (PSK).
Yes there are better ways such as using a PLL IC but that's no fun.
Rohm makes a nice IC that ties straight to the AC mains producing a 5v squarewave output at neg and pos cross over.
Pricey but sure helps with UC memory usage.
20ms would be 50hz.
Sounds an interesting project - let us know how it goes.
I just tested changing the ISR to just toggle the state of 'on' - and in the main loop have pin = on - still reflects the right time period, but still doesn't gp above 5kHz
Found the issue - unplugging the PICKit and the speed increase at which it works is dramatic - I changed to using 32MHz internal - and running happily at 100kHz (with mods as per previous post)
hippalator
Finally had an opportunity this weekend to go over your code which I very much appreciate.
Ive learned a lot from reviewing it. There is valuable insight ( for me anyway) on how things work in FC
Tho I'm not that familiar with C I can follow your code example quite easily except for a few things that I have looked up online.
I see you have declared a 100khz input pin.
A question I have is how do you know at 100khz its detecting?
You are flashing a pin in the ZCD_ISR but which one?
The pin declared in properties is for output - I'd connected this (RD1) to a logic analyser - it was easier than wiring up a UART convertor...
The zero crossing interrupts on RA0 - I think this is fixed on the 18877 - but other PICs might be able to remap to other pins.. This is set up (analog / input) in the interrupt enable block.
The output is defined in properties:
I would recommend doing pin assignments like this (rather than using Input/Output blocks) - except for very small pieces of code. It enables the pin to be changed easily (without having to alter all the Input/Output blocks) - and the pin can be written using pin = value or read using value = pin (where value will be 0 or 1)
Use of properties allows many very useful features - click add property and take a look...
- Has thanked: 468 times
- Been thanked: 697 times
Having never used a uC to perform ZCD I have been following this post with interest, especially the custom ISR. Hopefully I will get a chance to try it out.
Forty-odd years ago I used an Amstrad CPC464 (Z80 cpu) to control a bank of lights in a nightclub. All PAR36 bulbs with coloured gels at around 30 Watts each if memory serves. The cans were Mains fed. As you can imagine this would generate a lot of noise. My interface relied on "Out" statements and hardware decoding of the data bus to drive Triacs via opto-couplers. As the lights were all on the same phase, my ZCD solution was to take the AC output from the PSU transformer (which would ultimtely feed the control electronics) and route this through an opto-transistor to give a logical 1 or 0. This was fanned out to the decoded data bus and further discrete logic to only switch the desired Triac on if "crossing zero". This worked far better than I expected.
I also used a tunable audio filter in one routine that used the bass notes to clock the lighting changes.
Although a PIC16F18877 could easily do everything above in Flowcode, using gates bought from Tandy was a ton of fun....
