I currently have version 10.
But I have an old project generated with version 5 of Flowcode that I need to modify
Obviously, with F10 I can't open it.
Is there any way or system to do some type of work so that I can open the file with F10?
Thank you so much
Update project to F10
Carmelo
- Has thanked: 57 times
- Been thanked: 4 times
- Has thanked: 478 times
- Been thanked: 713 times
Re: Update project to F10
You would need to open the project in v7 then save it. After that it will open in all later versions. I forget the technical reason as to why though.
If you don't have a copy of v7 I'm sure someone will offer to convert. I have a copy and happy to do so, but I won't be at that machine until the weekend.
- Has thanked: 177 times
- Been thanked: 1027 times
You need someone with version 7 to convert (last version that can load the old v5 format) - if you PM your file to one of the VCs (myself, chipfryer27, medelec for example) we would do it for you - or post here?
There have been some changes to components etc, so it might take a little work after file conversion...
I attach the project here and tell me if it is better privately
- intermitencia_parada_emergencia.rar
- (2.59 KiB) Downloaded 186 times
Just re-downloading v7...
I'd like to reciprocate Iain's comment - so more likely he knows twice as much.... (or is that the reciprocal?)
Whatever it is, my brain hurts thinking about it..... must get better quality beer...
Edit...
Martin is obviously much smarter.... I never thought to just download it...... definitely need to get better quality beer....
Edit...
Opened then saved in v7.
This can now be opened in later versions. As Martin mentions above, you will need to check components etc to ensure things are as they should be.
- intermitencia_parada_emergencia_v7_Converted.fcfx
- (14.69 KiB) Downloaded 190 times
- (view online)
Whoosh - not just faster - better broadband too!!!
Looking at Skylink - and 100Mb/s is described as suitable for 'light browsing' (for the heavy stuff upgrade to 200Mb/s)
Wonder what BT's offering is good for???
