Move variables (Expressions) position in simulation list
RGV250
Has thanked: 46 times
Been thanked: 46 times
Post by RGV250 »
It does not look like you can move the order of the variable (Expressions) when simulating so you have to enter then in the right order, if you later want to add one you are stuck with it being on the bottom of the list which might not be where you want to view it.
Bob
Has thanked: 292 times
Been thanked: 458 times
Re: Move variables (Expressions) position in simulation list
Thanks. I'd add to our list for a way to move these around.
A workaround would be to replicate an existing expression/variable in the list at the bottom and then replace the original with a new expression/variable.
