using personnal arduino library insite flowcode
rowentaRT
Post by rowentaRT »
hi,
Would it be possible to include some personnal arduino library inside a embedded project ?
Hadrien
Has thanked: 468 times
Been thanked: 697 times
Re: using personnal arduino library insite flowcode
Post by chipfryer27 »
In Project Options, within the Other Options section you have a checkbox to Use Supplementary Code. If you tick tihis you can then specify a library to include.
Has thanked: 300 times
Been thanked: 465 times
Further to @chipfryer27's suggestion, there is more info about the Supplementary Code feature in the wiki and there are many posts on the forum that discuss it too. For example, see here:
https://www.flowcode.co.uk/forums/viewtopic.php?t=3359
rowentaRT
Post by rowentaRT »
thanks @steve-Matrix and @chipfryer. i will give it a try.
but some of my arduino libraries are not exclusively in C code but in C++.
Sometimes i also use Serial.print for debugging purposes. would it work in flow code ? mixing arduino commande such as serial.print or digitalWrite with the code generated by flowcode.
i have serious doubt that it would work. unluckily.
Has thanked: 633 times
Been thanked: 837 times
The UART component can replace the Serial.print for you, digitalWrite can be done by using an output icon.
What Arduino library are you interested in and maybe we can convert it into a Flowcode component for you.
Using an Arduino library directly in Flowcode at the moment without some form of conversion is likely to fail due to C / C++ incompatibilities. An AI agent would be very good at turning an Arduino C++ library into pure C code you can include from the supplementary code window.
