SmartScope Offer
Has thanked: 470 times
Been thanked: 699 times
Re: SmartScope Offer
Post by chipfryer27 »
Ha ha....
WingNut
Has thanked: 56 times
Been thanked: 43 times
Post by WingNut »
I got mine yesterday. Not had a chance to give it a thorough test but it looks sturdy and the software looks decent. Anyone know of a plug and cable that fits the logic port with a longer cable? I find the supplied leads a little short.
As you say its great for portability. Took a while to get here though
Rapid do 600mm. This is F2F but I'm sure F2M will be available too if required.
https://www.rapidonline.com/renkforce-r ... gKzJPD_BwE
CPC do 300mm
https://cpc.farnell.com/c/maker-circuit ... mper+Wires
Do buy from a "proper" source and avoid those from the cheap market sites as they are usually very low quality. I made a tester a year or two back and threw out the majority of those that came with "cheap modules". Turns out I didn't need to test as they, and the pins that came with them corroded during winter just in the cold air.
Has thanked: 177 times
Been thanked: 1016 times
Post by mnfisher »
WingNut
Post by WingNut »
The lab-nation one looks ok. Not sure I can wait another month tho. Might actually make one up myself from multi coloured ribbon cable and an IDE connector. Should have one around here somewhere
