esp32 i2c is not implemented yet
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Re: esp32 i2c is not implemented yet
Post by p.erasmus »
Hi Leigh
Thank you for the clarification, :D
I ran into an issue I made a small project for the ESP32 Lolin board and I wanted to just write a simple configuration to the I2C device and in the main loop switch a led on and off, to start too learn how to use this transactions macro`s :oops:
In FC chart the call is now disabled and I could program and my led is flashing.
All is working until I call the Transaction_write then the build fail and obviously no programming.
I am not sure what I am doing wrong please help.
ESP_HW_I2C_Example.rar
(5.29 KiB) Downloaded 760 times
LeighM
Has thanked: 110 times
Been thanked: 302 times
Post by LeighM »
Ah, good spot
Please could you change your DataArray from a string to a byte array
Default ESP compiler settings are somewhat pedantic about signed/unsigned mismatches
Hmm, something else for the WiKi :roll:
p.erasmus
Post by p.erasmus »
AHH Leight
I will give it ago right now thanks a million :D
I am stupid again byte Arrays are new for me in flow code how do i do that ? :oops:
I thought always Strings are all so byte arrays in Flowcode :oops:
p.erasmus
Post by p.erasmus »
OK I saw how Ben did it in his example I will try first
Thanks Leigh
LeighM
Post by LeighM »
p.erasmus
Post by p.erasmus »
Hura Success :D
Thanks a million Leigh :D
Just for me to be absolutely certain,I can now only use these transactions in I2C and it will probably work on PIC/AVR and ESP32-STM right no more Txbate and Rxbyte macros right?
LeighM
Post by LeighM »
Correct, well done :D
p.erasmus
Post by p.erasmus »
Hi Leigh
Thanks a million for all your help it is working fine now Transaction_read and Write so now I know how to implement the I2C in Future
:D :D
