Help with string error
aderito
Has thanked: 19 times
Been thanked: 2 times
Post by aderito »
Hello, I'm here to ask for help in trying to solve a problem I'm having in a project with a dspic33EV256GM006. I recently added a calculation icon to add several variables (strings) into one, and then send it via UART to another system. After a few attempts (Link Error: PC Relative branch to '___delay32' is out of range. Suggest large-code model.
) I realized I couldn't do something like: "string1 = string1 + string2" several times within the calculation. The intention was to sum the variables until finally sending them via UART. Then I tried sending them one by one through the component macro and it continued to give the same error. Of course, before doing that I deleted the calculation icon I had built earlier. If anyone here can help me, I would appreciate it.
display_app.fcm
(11.21 KiB) Downloaded 138 times
Has thanked: 649 times
Been thanked: 856 times
Re: Help with string error
I've tried to put togeter a simple test with your macro and the chip you specified, but it's compiling ok here.
You might need to attach your project so we can replicate exactly what you have.
FC_Test.fcfx
(18.71 KiB) Downloaded 144 times
aderito
Post by aderito »
Thank you for your reply. The project is a bit extensive, but I'll post it here anyway.
local V8HMI DS18B20.fcfx
(1.51 MiB) Downloaded 112 times
Has thanked: 312 times
Been thanked: 479 times
It looks like your project is very large and the compiler fails to compile the code because the call for a delay icon and the actual code for that delay call are too far away from each other.
You could try to reduce the size of your project by removing unnecessary macros and combining duplicate code where possible.
Alternatively, you could try using the "-mlarge-code" command line switch on the compiler. This is done in the "pic16_C30_compLarge.bat" file and instructions for this are in our old forum here:
https://flowcode.co.uk/mmforums/viewtopic.php?t=21926
aderito
Post by aderito »
Steve-Matrix wrote: ↑
Mon Apr 20, 2026 2:57 pm
I'm having trouble configuring the compiler. Is there something I'm doing wrong?
mensagem compilador.png (182.92 KiB) Viewed 5283 times
It's difficult to see with the images - posting the msg.txt output as text or attaching the file may have been better - but it looks like you are not pointing Flowcode to the correct location of the batch files. Also, the parameters look wrong too.
I think this is because the information on our old forum is for Flowcode v7 and locations have changed for more recent Flowcode versions.
For v11, the Compiler batch file should be in the same folder as the normal default, so the "Location" field should be:
$(fcddir)PIC16\batchfiles\pic16_C30_compLarge.bat
And the "Parameters" field should be the same as the normal default, ie:
"$(compilerpic16)" "$(target)" "$(outdir)" "$(chip:u)"
Similarly, the Linker location and parameters should be:
$(fcddir)PIC16\batchfiles\pic16_C30_linkLarge.bat
"$(compilerpic16)" "$(outdir)$(target)" $(chip:u) $(family)
aderito
Post by aderito »
Wed Apr 22, 2026 10:44 am
Thank you very much Steve, it's all good now. That was the problem after all, I was using the guidance for an older version and the one I'm using is Flowcode v10.
Excellent - thanks for letting us know.
