Can you add a feature like as "Print Letter" to component macro 74hc595 7 segment ?
Thank You.
Sameh Philipp
Feature Requests
sameh_philipp
- Has thanked: 2 times
- Has thanked: 158 times
- Been thanked: 927 times
Re: Feature Requests
It is relatively easy to do using the 'segments' function.
Have an array for the characters you need - not all characters are possible but a fair few are so use ASCII mapping (' ' (space) is 32, 'A' 65 etc) - and I would offset the index (use .c - 32 where .c is the character) as 0..31 are not 'printable'
Then you have .segments = char_set[.c -32] ChatGPT (or alternative) will generate the lookup table for you
sameh_philipp
hello mnfisher
thank you very much for your help, I appreciate so much,.
Regards..
Regards..
Sameh Philipp
Have a play - see how you get on...
See https://www.flowcode.co.uk/forums/viewt ... 898#p21898 - where I do this for the MAX7219 7 segment display.
You could maybe 'borrow; the character set?
