Hi Guys im using the Simcom A7682E and there is a problem with the firmware. It only sends me back UCS2 format back when reading the airtime balance. I have spoken the Simcom and they busy working on the firmware but who knows how long it will take. What i need is to make a macro to convert the UCS2 to text. I have asked Ai to help and it came up with this C code but dos not work when i compile it dose not recognize the variables which i have created. Is there a way to create a macro that will convert it as i have no idear where to start with it.
Ai Generated C Code
// UCS2 to Text Conversion - Fixed Version
unsigned int i, j = 0;
unsigned char val;
for(i = 0; i < strlen(CollectNumber)-3; i += 4)
val = 0;
// High nibble
if(CollectNumber[i+2] >= '0' && CollectNumber[i+2] <= '9')
val += (CollectNumber[i+2] - '0') * 16;
else
val += (CollectNumber[i+2] - 'A' + 10) * 16;
// Low nibble
if(CollectNumber[i+3] >= '0' && CollectNumber[i+3] <= '9')
val += (CollectNumber[i+3] - '0');
else
val += (CollectNumber[i+3] - 'A' + 10);
CleanText[j++] = val;
CleanText[j] = 0; // Null terminate
Compiler Errors
E-P_U6_V-4-6-2_BaseV9_16-05-26_For-A7682E.c: FCM_Read_buffer()
8608: for(i = 0; i < strlen(CollectNumber)-3; i += 4)
^ (361) function declared implicit int (warning)
^ (192) undefined identifier "CollectNumber"
8613: if(CollectNumber[i+2] >= '0' && CollectNumber[i+2] <= '9')
^ (981) pointer required
(981) pointer required ^
8614: val += (CollectNumber[i+2] - '0') * 16;
8616: val += (CollectNumber[i+2] - 'A' + 10) * 16;
8619: if(CollectNumber[i+3] >= '0' && CollectNumber[i+3] <= '9')
8620: val += (CollectNumber[i+3] - '0');
8622: val += (CollectNumber[i+3] - 'A' + 10);
8624: CleanText[j++] = val;
^ (192) undefined identifier "CleanText"
E-P_U6_V-4-6-2_BaseV9_16-05-26_For-A7682E.c: 8627: too many errors (21)
(908) exit status = 1
Error returned from [xc8.exe]
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1
Autoclose turned off
FINISHED
UCS2 (UTF-16BE) to text
jollybv
- Has thanked: 42 times
- Been thanked: 15 times
- Has thanked: 177 times
- Been thanked: 1020 times
Re: UCS2 (UTF-16BE) to text
It should be straightforward to display - at least for the standard character set. UCS2 stores data as 16bits so allows 65536 characters - ASCII is 8 bit (32..127) as a subset.
So one option is to just convert from 16bit to 8bit. This will depend on the byte order on the device but:
.char = .ucs2 // char is byte
Or
.char = .ucs2 >>8
For each character...
How do you have the ucs data stored - a macro UCS1ToASCII(UINT data[20], length n) returning a string:
loop .i .n times
.result[.i] = .data[.i] // Strip extra byte from data (0 is end of string char!)
return .result
Or
.char = .ucs2 >>8
loop .i .n times
return .result
In code:
Assuming little-endian here.. If the device uses big-endian data then add the shift.
- ucs2.fcfx
- (11.51 KiB) Downloaded 56 times
- (view online)
