gLCD_GC9A01A_SPI component bug when compiling
rokaluzas
Has thanked: 2 times
Post by rokaluzas »
Greetings!
I have an issue with flowcode v11, when I just add component gLCD_GC9A01A_SPI and try to compile it to .hex I get this error:
Device STM32F051x8
Gauge.c:219:9: error: expected expression before ',' token
0xEF, 0,,
Error(s) in build
C:\ProgramData\MatrixTSL\FlowcodeV11\FCD\ARM\batch\stm32comp.bat reported error code 0x1
Autoclose turned off
If I use the same component on Flowcode v10 it generates .hex without any issues, is there some way to fix this issue?
Thanks for the help!
Has thanked: 311 times
Been thanked: 479 times
Re: gLCD_GC9A01A_SPI component bug when compiling
Can you please post a sample project with the error and we'll take a look.
rokaluzas
Post by rokaluzas »
Hey!
Thanks for reply! I've attached a program file, You should be able to trigger the error when compiling to .hex with Flowcode V11.
GC9A01A_test.fcfx
(14.09 KiB) Downloaded 148 times
Thanks for that. We're investigating and hope to have a fix for you soon.
rokaluzas
Post by rokaluzas »
Thanks, I’ll be looking forward to it.
Has thanked: 647 times
Been thanked: 856 times
Many thanks for letting us know on this one.
I've sorted the problem and the fix should now be available for you via the Help -> Library updates.
