array size seems to be limited
Jorg_Guldner
Been thanked: 4 times
Flowcode v10 array size seems to be limited
Post by Jorg_Guldner »
Hello!
I need an array size of 96. Defining the array shows under variables only a maximum of 24 and the program is not working?
Any idea?
Jorg
Has thanked: 311 times
Been thanked: 479 times
Re: array size seems to be limited
This is normal - only the first 25 array values are shown. If you need to view or alter the value of an array element above index 24, you can add a suitable expression - e.g. sensor_1_array[90] - to the watch window area of the Simulation Debugger when running the project via simulation or ICD.
Has thanked: 177 times
Been thanked: 1026 times
Post by mnfisher »
The display only shows some (the first ...) but you should be able to use large arrays (Ive used 50000 elements) - assuming the device has sufficient RAM.
Can you post some code demonstrating the issue?
Jorg_Guldner
I found the program bug. array[24] have the address 0-23 ! I uses 1-24 and the program writes into a other variable.
The other info, that only 24 variables are shown is a point that is new for me.
Thanks to you
Jorg
Post by mnfisher »
Glad you've found the issue.
Some languages do use '1' based but this is much rarer - and loops to process the array would also tend to be '0' based (loop count 24 times using a variable .i - .i will take the value 0..23)
Has thanked: 796 times
Been thanked: 858 times
I have move this topic to a more appropriate section, as it is not a Flowcode bug.
