Scada advice needed.
astro123
Has thanked: 8 times
Post by astro123 »
Hi.
Looking for advice on getting this flowcode v9 Scada file working, using an Arduino uno.
The uno is working when I load a flowcode v9 leds file.
But the Scada file does nothing, do I need to install a file for the Uno, before running flowcode v9.1?
Or am a missing some thing in my Scada file.?
System layout
Win10 pro, all updates
Flowcode V9.1 all updates.
Regards Roy
Also tried flowcode v8, no luck yet, all updates installed
Scada_Led.fcsx
(9.51 KiB) Downloaded 495 times
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Re: Scada advice needed.
Post by p.erasmus »
You need to flash the UNO with the SCADA hex file(which is down loadable from the UNO scada wiki page) before you can run scada from Flowcode is my understanding of SCADA
then you need to place a UNO Scada component on your panel if you make a new FC chart and want to use SCADA
astro123
Post by astro123 »
p.erasmus wrote:
Sat May 08, 2021 3:55 pm
Thank for the info, :D was using the wrong hex,found the right one on wiki
now all is working
Regards Roy.
Has thanked: 707 times
Been thanked: 768 times
Hi, Roy.
For details on how to set up the App to store properties and data + graph etc. I would suggest looking at the code for Three channel temperature logger - Arduino, USB available from here
For future reference, the instructions within Documentation link, gives you a step by step guide on how to get the App Developer set up and running.
