Unable to upload sample program to M5 Stack
Jpeake1009
Post by Jpeake1009 »
Hi All
i have downloaded the test screen sample from the support section but i have been unable to build and load to my M5 dial.
The error the occurs is a syntax error on line 6888, however when i interigate the code it seen perfectly fine.
any advice would be appreciated
Has thanked: 625 times
Been thanked: 833 times
Re: Unable to upload sample program to M5 Stack
Please can you attach your project file and the associated .msg.txt file it sounds like you might be getting a compiler error.
