ST7735R
Been thanked: 3 times
ST7735R
Post by 17712885438 »
Could FC add a ST7735R macro? thank you.
Has thanked: 647 times
Been thanked: 856 times
Re: ST7735R
That should be there and supported already under Displays -> Graphical Colour.
17712885438
Re: ST7735R
n the FC, there is only ST7735, but no ST7735R.
Re: ST7735R
I've checked the component source and the existing component should run on both the ST7735 and ST7735R.
Have you tried the component with hardware?
17712885438
Re: ST7735R
I have already tested it on the hardware ST7735R, but it didn't work. I also conducted simulation tests on the ST7735R in PROTEUS, but it didn't work either. I checked the information and found that ST7735 and ST7735R are different from each other.
Re: ST7735R
I've been through my pile of displays and only seem to have the ST7735S version so I've bought this for testing and it should arrive next week.
https://www.amazon.co.uk/ST7735R-Displa ... B07XTDMQQS
I'll let you know.
Re: ST7735R
Right the display I got is working great with the existing component.
One thing that threw me for a while was the board had a SC card socket and the pins labelled MISO, MOSI, SCK were actually for the SD card. Connecting the SPI display connections to pins marked SDA and SCL allowed the display to function.
MOSI -> SDA
SCK -> SCL
