The digital input isn't working. What might I have configured incorrectly?
Please help.
MCU: PIC18F47Q10
I am uploading the project.
Title:
Description:
Device: PIC.18F.18F47Q10
Generated by: Flowcode v11.0.2.17
Date: Wednesday, September 09, 2026 17:34:54
Users: 1
Registered to:
Licence key:
https://www.flowcode.co.uk
Using <2.50> user settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV11\FCD\PIC\batch\pic_xc8_comp.bat "C:\Program Files\Microchip\xc8\v2.50\pic\bin\" 18F47Q10 "C:\Share_KDT2\!Project_Ing\260906-YEOSUWA-HumanCount\Program\" "260909-Counter"
C:\Share_KDT2\!Project_Ing\260906-YEOSUWA-HumanCount\Program>REM CRC: 90CF26913586BBA787FE92D553771933222DCF72B25FEB4608E17FBD060500D8A6D7AF8357042D9E8B5C2E833010A32BE2214988CBC1BB00301ECF6745983589A9CE866D3EBD48DE4910375451077F45562AF2F62E9AB6760C3CAEE8E7DA6987B08235BD4F165DE350CACCEB0B5A8E521002EAF3D15174CD20633AD186EC562DBEEF6112EA5AA5CF5041CCE14E8D252BC416ECB8EC7761E4FD518969900F56C6C8F36CE7BEFFD91E73F563CBE7F64B8A69F01B3F3C0F45102C3050DA273BE4EE464087EABAE4073CCE8590A2034B265B899B535CCC0630944A53779878588293DF04F96FE36F6B2B
C:\Share_KDT2\!Project_Ing\260906-YEOSUWA-HumanCount\Program>REM REVISION: 5.0
C:\Share_KDT2\!Project_Ing\260906-YEOSUWA-HumanCount\Program>REM GUID: 50CB4B58-ED9C-4591-8D65-A87DE810E8CC
C:\Share_KDT2\!Project_Ing\260906-YEOSUWA-HumanCount\Program>REM DATE: 12\06\2025
C:\Share_KDT2\!Project_Ing\260906-YEOSUWA-HumanCount\Program>REM DIR: FCD\PIC\batch\pic_xc8_comp.bat
C:\Share_KDT2\!Project_Ing\260906-YEOSUWA-HumanCount\Program>"C:\Program Files\Microchip\xc8\v2.50\bin\xc8.exe" --chip=18F47Q10 "260909-Counter.c" --double=32 --float=32 --msgdisable=359,1273,1388
C:\Program Files\Microchip\xc8\v2.50\pic\bin\picc18 @C:\Users\daniel\AppData\Local\Temp\xcAsft0.\xc8_tmp_0.cmd [ --chip=18F47Q10 260909-Counter.c --double=32 --float=32 --msgdisable=359,1273,1388 ]
Microchip MPLAB XC8 C Compiler V2.50
Build date: Jul 25 2024
Part Support Version: 2.50
Copyright (C) 2024 Microchip Technology Inc.
legacy HI-TECH support is deprecated and will be discontinued in a future release; consult the release notes for more details
legacy C90 library is deprecated and will be discontinued in a future release; consult the release notes for more details
using updated 32-bit floating-point libraries; improved accuracy might increase code size
18F47Q10 Memory Summary:
Program space used 6B0h ( 1712) of 20000h bytes ( 1.3%)
Data space used 77h ( 119) of D1Fh bytes ( 3.5%)
Configuration bits used 6h ( 6) of 6h words (100.0%)
EEPROM space used 0h ( 0) of 400h bytes ( 0.0%)
ID Location space used 0h ( 0) of 100h bytes ( 0.0%)
Compilation successful!
Using <2.50> user settings for linker
C:\Program Files (x86)\Flowcode v11\tools\DoNothing\DoNothing.exe
FINISHED
Digital Input read error
seokgi
- Has thanked: 8 times
- Been thanked: 9 times
- 260909-Counter.fcfx
- (24.99 KiB) Downloaded 10 times
- (view online)
- Has thanked: 177 times
- Been thanked: 1016 times
Re: Digital Input read error
What do you mean 'doesn't work' - looks to compile successfully..
Does the heartbeat 'pulse'? Can you output anything to RS232?
It works correctly with compiler version 2.10. With compiler version 2.50, it compiles successfully and the UART functions properly; however, the digital input fails to read values. I have not tested other functions.
