Good morning
I am having a small problem with, figuring out how can I get my keypad to dial 7-digit numbers then initialized a call
In my current program;
If I press "#" ALONE it sends off and makes a call
If I dial any 1 or up to 6-digit numbers, it sends off and makes a call
What I want is Only when I Reach 7 digits Then that's the time it should make a call.
Any Help? Please and thank you.
TouchScreen Dial Keypad
daddytims_tims
- Has thanked: 126 times
- Been thanked: 13 times
- Has thanked: 177 times
- Been thanked: 1026 times
Re: TouchScreen Dial Keypad
Assuming '#' is widget 12 - you have if widgetpressesd = 12 ... cmd = ATD876 + tmpstr.+ "\r\n" - which I'd guess does dial.
You perhaps want to add a check that tmpstr contains sufficient digits for a valid number (if (widgetpressed == 12) && (Length$(tempstr) == 7))) then dial...
or Length$(tempstr) >= 7 - to allow for longer strings - although you might want to truncate - or throw an error if tempstr has more than 7 digits?
daddytims_tims
Goodmorning.
Thanks for your help.
The first one works great for me..
I prefer for it to be exact 7 as i already have the area code inside the prgramm already...
So how do I set it to be. If greater than 7. Throw in an error ?
Goodmorning.
Glad it worked.
As to an error - depends how you want to handle it - for example you could ignore digits after 7 have been entered.
Or - better:
You could alert the user - display an error message (invalid phone number?) - similarly - if the user presses '#' before sufficient digits - display - "invalid number please enter 7 digits"
Or - better:
daddytims_tims
Thats awsome. I would prefer the second option.
How can I set that up?.
I'm not at a computer - but.
Something like:
Add a macro Dial(string number)
Then in your loop - if (widgetoressed ==12) Dial(tmpstr)
In Dial (number)
.len = LengthStr$(.number)
if(.len != 7) Message("Invalid number - please enter 7 digits)
else
.msg = "Dialling " + .number
Message(.msg)
.... do the call ATD....
Message("Hanging up")
etc
Something like:
In Dial (number)
else
Message(.msg)
etc
