Hi Team,
I noticed that UART RX interrupt doesnt seem to work during simulation, is it possible to have UART RX interrupts in simulation? Thanks!
UART RX Interrupt in simulation
evolutiongtx
- Has thanked: 795 times
- Been thanked: 858 times
Re: UART RX Interrupt in simulation
Hi, evolutiongtx.
No, sorry. RX interrupt has never been able to simulate.
What I do is use IsSim to call the RX macro during simulation only.
I can help you with that if you are stuck.
evolutiongtx
I would greatly appreciate it, how would I be able to do that? Thanks!
evolutiongtx
Hi, evolutiongtx.
I have attached a flowchart that works with Is Sim & keybinding to r.
To change the key, select Edit ribbon, and Key mappings
Unfortanlty, the flowchart will not fully work as injectors are in the process of being phased out and replaced with API calls.
However, there should be enough to give the basic idea.
If you are still a bit stuck, can you post your flowchart & I will modify it for you?
- Is Sim & Keybind RX Interrupt.fcfx
- (16.73 KiB) Downloaded 610 times
- (view online)
