ESP tool chain not installed!
jgu1
Has thanked: 910 times
Been thanked: 219 times
Post by jgu1 »
Hi!
Just received my ESP 32 and want to test. After install the toolchain I try to compile to chip, I get the message "ESP toolchain not installed is there some special I have to do?
Br jorgen
LeighM
Has thanked: 110 times
Been thanked: 302 times
Re: ESP tool chain not installed!
Post by LeighM »
Did you follow all the instructions in the link below, carefully :D
... including the Flowcode Global setting?
https://flowcode.co.uk/wiki/index.php?t ... Toolchains
jgu1
Post by jgu1 »
Tryed again, and yes, I have forgot the location in global setting, sorry. Now it begin to compile, but will not program the ESP32
LeighM
Post by LeighM »
You also need to set the COM programming port, see this post ..
viewtopic.php?p=57#p57
Some ESP modules also need the BOOT switch pressed when programming.
jgu1
Post by jgu1 »
Hi LEigh!
Your suggest already tryed. I cannot see any comport in the settings , no matter what I do. I hear the pling when I connect the USB and see Com17 when I att the USB in devicemanager
jgu1
Post by jgu1 »
Hi Leigh!
What can I do please ;)
Br
Jorgen
LeighM
Post by LeighM »
Have you selected COM17 as the programmer port on the Project Options screen?
This works similar to the port for Arduino programming.
jgu1
Post by jgu1 »
Hello Leigh!
Ok, well, could not find it in the manual :lol: :lol:
Now I can compile. Thank you.
Br Jorgen
