External interupts
dz2869
Has thanked: 1 time
Been thanked: 1 time
External interupts
Post by dz2869 »
Trying to convert a V8 project to V9.
PIC18F45K40
I am using External Interrupts INTR0 and INTR1 on B0 and B1
They work fine in V8 but do not seem to be working in V9
Attached is a small project that demonstrates the problem.
The program should toggle between the numbers 1 and 9 on the display.
Seems that INT0 always triggers INT1 so the number 9 is always displayed.
Thanks for any help on this one.
Ext_Interupts.fcfx
(12.16 KiB) Downloaded 438 times
dz2869
Has thanked: 1 time
Re: External interupts
Post by dz2869 »
Anyone had a chance to look at this one yet?
Has thanked: 510 times
Been thanked: 700 times
I've compared the C code produced by v8 and v9 for your project file and the C code appears to be identical.
I would be interested to know if your v9 is using the latest PIC compiler or if using the same PIC compiler as v8. You can check this by going into View -> Global Settings -> Locations tab and looking at the Override toolchain locations for PIC.
The v8 compiler will look something like this.
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\
whereas the v9 PIC compiler will look something like this.
C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\
If we can narrow it down to a compiler issue then it makes it easier to try and find the solution.
dz2869
Has thanked: 1 time
Post by dz2869 »
Ben,
I actually haven't tied running the compiled V9 code on actual hardware yet.
I stopped after seeing that the program did not simulate correctly inside the flowcode application.
Maybe its just a simulation issue.
I'll check on the compliers
Thanks,
Dave
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Post by p.erasmus »
Interrupts does not simulate in any version of Flowcode ,even in your V8 the code will not simulate :D maybe it worked in Hardware :D
Pin based interrupts should work fine. That helps me narrow down where I'm looking. I'll have another look for you now.
Edit. Found and fixed the problem and posted the fix to the update system. Thanks for letting us know.
dz2869
Has thanked: 1 time
Post by dz2869 »
Working now
