if I try to open the forum with the project open it does not open....
thanks.
solozerouno.
bug on forum open with open project
solozerouno
- Has thanked: 2 times
- Been thanked: 2 times
- Has thanked: 294 times
- Been thanked: 459 times
Re: bug on forum open with open project
I've just tested this and it is working ok for me.
What do you see? Does a window open with no forum inside, or does the window itself fail to open? Or is the forum window docked to your main Flowcode window, but needs to be expanded?
If a window does open then perhaps there is something preventing the html page from loading. Does the Wiki and Licensing pages have the same problem?
If the window doesn't open at all, then there could be a problem with the window positioning information stored in the registry. This can happen if the monitor arrangements have changed since a previous save. Please send me (by PM) you registry information and I will confirm. The hive you need to export is:
HKEY_CURRENT_USER\Software\MatrixTSL\FlowcodeV9
solozerouno
solozerouno
the problem is partially solved if I am with the icons open and the main present I press the forum and the writing in the main panel flashes every time I press forum, same problem with wiki.....
thanks
thanks
