Ok thanks for comfirming, doing a compile test now to double check things this end.
edit - I've got the same problem. On with trying to resolve it for you now.
ESP32 problem with components
- Has thanked: 647 times
- Been thanked: 856 times
Re: ESP32 problem with components
Should be all sorted for you now with the latest RMT component via the update system.
Thanks for bringing the issue to our attention.
- Has thanked: 246 times
- Been thanked: 258 times
Perfect! It's compiling and working again.
A little hint, the Led's only light up when I do a little delay after the drawline and before the refresh.
And there is an another litle problem with ESP32 and a component what I can not solve...
The HX711 component is alway give back 0.
https://flowcode.co.uk/forums/viewtopic.php?f=3&t=480
- FC9_M5STACK Modul Atom Matrix_empty.fcfx
- (11.33 KiB) Downloaded 453 times
- (view online)
