Open projects with german letters are aborted
Jorg_Guldner
Been thanked: 4 times
Post by Jorg_Guldner »
Hello!
All my projects can be open with all older programs. V9 aborted if there are german letters like "äöüÄÖÜ" in the file name.
Jörg
Has thanked: 258 times
Been thanked: 413 times
Re: Open projects with german letters are aborted
Hello Jörg,
Thanks for the bug report. It seems like launching the Flowcode file by double-clicking it has the problem. However, running Flowcode directly and opening the file from the "file...open" menu seems to be ok. Is this what you are experiencing?
I will try to implement a fix in a later update of Flowcode.
As a workaround, you can either open projects from the "file...open" menu, or rename the project file so it does not use these problematic characters.
HTH,
Steve.
I have just looked into the problem and the fix was fairly easy. The ZIP attached to this post contains a new version of the launcher exe (this now one is v9.0.1.2).
To fix your issue, download and unzip this file and replace the <FlowcodeLauncher.exe> file which is in the "launcher" folder of your Flowcode installation.
Please let me know if this works ok for you.
FlowcodeLauncher.zip
(37.22 KiB) Downloaded 358 times
Jorg_Guldner
Hello!
The Launcher is working. I could open a project by double clicking on it without any errors.
Well done!
Jörg
