INT OSC in PIC 16LF1823
mehmet64
Has thanked: 8 times
Been thanked: 4 times
Post by mehmet64 »
hi
i try too use INTOSC in one Project with a 16LF1823 but this not working prperty after program Micro///this just working property wen i set FREQ in 0.5 MHZ and PWM out put FRQ is not true i see with osiloscope ///when i set PWM FRQ to 38 kHZ micro provide 1 KHz PWM
mehmet64
Re: INT OSC in PIC 16LF1823
Post by mehmet64 »
This is my project
Test.fcfx
(9.68 KiB) Downloaded 474 times
Has thanked: 607 times
Been thanked: 803 times
On the component toolbar look under Runtime -> Matrix tools for the IntOsc helper component.
This lists the speeds that the internal oscillator on your selected device can run at and also lists the line of C code needed to be inserted after the start icon to configure the chip to run at the selected speed.
For 0.5MHz you need to use the following line of C code at the start of your program.
OSCCON = 0x38;
Hopefully this helps.
mehmet64
Post by mehmet64 »
hi
thank you very much
