Read IP ESP32
jollybv
Has thanked: 42 times
Been thanked: 15 times
Read IP ESP32
Post by jollybv »
Hi Guys
I'm trying to understand the WLAN component of the esp32, I would like to read the IP of the esp32 I have tried the IP=WLAN_ESP32::ReadIPString() component and it just gives me 0.0.0.0 so not sure what I'm doing wrong. I have tried setting it up as an access point then reading the IP ADD but alas noting.
Access_point.fcfx
(19.46 KiB) Downloaded 422 times
jollybv
Re: Read IP ESP32
Post by jollybv »
Hi Guys
I sorted out reading the IP i was trying to create an access point instead of connecting to the SSID of my rougher now the only thing is that it reads the IP backward is this a fault of the component?
IP address.png (6.76 KiB) Viewed 3499 times
Access_point.fcfx
(21.74 KiB) Downloaded 530 times
Has thanked: 724 times
Been thanked: 783 times
Re: Read IP ESP32
Hi Brian,
Thank you for the spot.
I have hopefully fixed the issue.
I will ask Ben to add the component to the update system.
Re: Read IP ESP32
Hi Brian.
The component is now on the update system.
