Component DS18B20
rzeszurzeszu
Been thanked: 2 times
Component DS18B20
Post by rzeszurzeszu »
Hello Guys,
After database update there is not possible to select the connection pin for DS18B20 in the component properties.
do you see the same issue ?
Has thanked: 794 times
Been thanked: 858 times
Re: Component DS18B20
Hi rzeszurzeszu.
One Wire components have been greatly improved so that it now supports multiple one wire components and support for slower running microcontrollers.
Right-click on the DS18B20 on the control panel and select Help.
THe help page that opens up will have some example Flowcharts.
Has thanked: 647 times
Been thanked: 856 times
The OneWire components such as the DS18B20 require connection to a host OneWire component, available under the Comms menu.
The host OneWire component has the pin connection property.
