Help with C++ Code to Flowcode Conversion
Has thanked: 105 times
Been thanked: 516 times
Re: Help with C++ Code to Flowcode Conversion
Post by mnfisher »
Random in Flowcode returns a value between 0 and 0xFFFF
To 'clamp' it to -2..2
.hSkew = (random() % 5) - 2
should do what you need
% operator is mod (modulus) - so random() % 5 will return a number in the range 0..4 then -2 gives -2 .. 2
unity-control
Has thanked: 26 times
Been thanked: 11 times
Post by unity-control »
Excellent Martin, thanks for all of this! It is all very clearly explained.
Cheers!
R
Post by mnfisher »
Oop - just thought of a problem with the random code.
If random generates a negative number I'm not sure if the remainder can be negative (some testing might be in order)
If it can you'll need
... = (random() & 0x7fff) % 5 ... To clear the sign bit.
unity-control
Understood Martin, thanks for ALL your comments.
R
