gLCD 7789 & SPI component clash on ESP32
jollybv
Has thanked: 42 times
Been thanked: 15 times
Re: gLCD 7789 & SPI component clash on ESP32
Post by jollybv »
Have been crazy busy for the last few weeks so have not been in to check messages. I will go update shortly and let you know what I find
jollybv
Post by jollybv »
I got time to test the system and there seems to be a problem now that I have updated the components the program wont compile I have not changed anything other then update the components and I get the following error message.
error message.png (72.14 KiB) Viewed 9634 times
LeighM
Has thanked: 110 times
Been thanked: 302 times
Post by LeighM »
Please could you attach the project msg.txt file?
That will help much better than a partial screen shot
jollybv
Post by jollybv »
Hi Leigh
Here is the Compiler message
Compiler Message.txt
(61.93 KiB) Downloaded 838 times
LeighM
Post by LeighM »
Thanks.
Looks like there is an issue in DSPOutput::GetFloat()
I'll leave it for Ben to look at :)
Has thanked: 647 times
Been thanked: 856 times
I can't seem to replicate this one. I'll keep looking.
Can you confirm if it's still a problem with the latest updates? You might need to do a full database update to get all the latest DSP related bits.
jollybv
Post by jollybv »
I just did a full update but problem still there I'm going to PM you the program and see if you can replicate problem
jollybv
Post by jollybv »
Did you get a chance to look at the program I sent you in a PM as to why it will not compile?
jollybv
Post by jollybv »
Hi Guys
I still have not been able to sort the compiling error out
(62.59 KiB) Downloaded 761 times
Really not sure how to go forward I have done all the updates with no luck.
Has thanked: 311 times
Been thanked: 479 times
The error location has changed for some reason. Your original one was:
../main/esp-project.c: In function 'FCD_0e811_DSPOutput1__GetFloat':
../main/esp-project.c:975:29: error: implicit declaration of function 'DSPBuff_0_Get'; did you mean 'DSPBuff_2_Get'? [-Werror=implicit-function-declaration]
 #define DSPOutput1_Ref1_Get DSPBuff_0_Get
...but now it is this:
../main/esp-project.c: In function 'FCD_0db01_DSPPIDControl1__Process':
../main/esp-project.c:942:33: error: implicit declaration of function 'DSPBuff_0_Get'; did you mean 'DSPBuff_2_Get'? [-Werror=implicit-function-declaration]
 #define DSPPIDControl1_Ref1_Get DSPBuff_0_Get
It looks to be the same error, but is now in another part of the code. Did something change in your project to cause this?
