UART2 Rx data problem
Xbiotec
Has thanked: 37 times
Been thanked: 27 times
Post by Xbiotec »
hi,
I'm using ESP32 TTGO Display to receive data from $PortA.26 with UART2 then transfer these data to Computer with UART1 (Tx $PortA.1, Rx $portA.3).
Problem is that UART2 received data are always 255 ! but as you cans see below, the signal to $PortA.26 is not always 255.
So I made a test with and without data input
- When data wire disconnected from $PortA.26 , input data = 0 see below
- when data wire connected from $PortA.26 , input data = 255 see below
Data on screen
I don't know what's wrong, please check.
Seb
Xbiotec
Re: UART2 Rx data problem
Post by Xbiotec »
sorry can not add the files to first post
Data disp.fcsx
(30.82 KiB) Downloaded 1963 times
Data disp.fcsx
Seb
Data_Send2.fcfx
(28.63 KiB) Downloaded 1610 times
Seb
Has thanked: 647 times
Been thanked: 856 times
Hi Seb,
Please can you try this slightly modified program. This should interrupt on every byte received and add each byte to the circuilar buffer one at a time. Before I beleive you were trying to do a bit too much inside the interrupt.
When we have at least 4 bytes in the buffer we re-send them to the PC and display on the LCD.
Data_Send2.fcfx
(27.23 KiB) Downloaded 1611 times
I'm not sure on the data you're working with but you can use the CB component to do things like wait until you get a specific character and then go from there allowing you to sync up correctly with the data you're receiving and throw any surplus data away.
Let us know how you get on.
Xbiotec
Post by Xbiotec »
Thx Ben for your prompt reply, I just test it and the result is NG.
FYI, the data are from a sensor who is pushing 16 bytes every each second (1hz)
The first and second bytes to receive are always Byte0=0X42 and Bytes01=0x4D
For example,: 42 4D 0C 51 09 A2 07 2B 01 35 05 81 20 08 20 AD
66:77 received are ok --> 0x42 0x4D
Seb
Seb
Hi Seb,
Looks like you're getting some data through now.
What about this instead?
Data_Send2.fcfx
(21.92 KiB) Downloaded 1775 times
This waits for the first two bytes to be received, throwing anything else away. Once the bytes are received it waits for the buffer to fill with a complete reading of 14 data bytes. Once this happens it transfers everything through to the PC and prints out the first four data values on the LCD.
Watchdog delay reset was caused by the lack of delay in your main loop so I've put this back in now.
Sorry missed the ':' characters in between the numbers.
Data_Send2.fcfx
(22.45 KiB) Downloaded 1689 times
Xbiotec
Post by Xbiotec »
Im testing,
what do you mean by " CB component" when you said "you can use the CB component to do things like wait until you get a specific character" ?
Seb
Xbiotec
Post by Xbiotec »
Thx a lot Ben it works very well !!!! :D :D :D
may be I will need your help to send data to sensor next week.
What is "CB component" ?
BIG THANKS
Seb
Has thanked: 794 times
Been thanked: 858 times
lucibel wrote: ↑
Fri Nov 26, 2021 6:12 pm
It's the Circular Buffer component.
It's very useful if receiving a fair bit of comms data.
Xbiotec
Post by Xbiotec »
Okay, understood now, yes very useful
Thx Martin
Seb
