ESP8266 Connect to SSID wrong feedback
kabouras_33
Been thanked: 7 times
Post by kabouras_33 »
Hello guys,
I am currently working on a new system using pivc18F27Q10 and an esp01 with AT 1.7.5 firmware.
My problem is that the function Connect to SSID, no matter if it connects or not , it always returns 1.
I need to be able to check if connected to reconnect or not...
Any help appreciated
Has thanked: 246 times
Been thanked: 258 times
Re: ESP8266 Connect to SSID wrong feedback
Hi Kabouras
Just a little question. Would you like to use an ESP32 instead of PIC and ESP8266? Or you can also use the PIC and an ESP32. In the ESP32 you can write programs for WiFi or Bluetooth yourself and connect to the PIC with the UART.
Amtor
Has thanked: 21 times
Been thanked: 16 times
Post by Amtor »
I think I had that problem, I think I used the get IP address cmd and if a valid address appeared used that to confirm connection.
Mark
Amtor
Post by Amtor »
Just checked the AT version of the one I’m using at the moment and it’s 1.3.0.0 (Jul 14 2016)
That one seems to respond correctly.
Mark
