Way to send data from UART
Xbiotec
Has thanked: 37 times
Been thanked: 27 times
Post by Xbiotec »
I just made a sample program to send data from UART to a Sensor.
Could tell me if this is the good way to send data a the good baud rate or do you have a better way even without LUT, with a string or EEPROM etc...
send to UART.fcfx
(10.8 KiB) Downloaded 484 times
Seb
Has thanked: 616 times
Been thanked: 815 times
Re: Way to send data from UART
That looks good to me. It really depends on if you need to be able to send different things.
As the data is fairly small you could send as a string using the following fixed string parameter. Sending as a string won't allow you to pass the value 0x00.
"\x64\x69\x03\x5E\x4E"
Or you could pop the values into a byte array and send the array. This will allow you to send the value 0x00.
data[0] = 0x64
data[1] = 0x69
etc
Xbiotec
Post by Xbiotec »
hi Ben,
I did different test
1- SendString like you proposed to me:
Data are well send in simulation but can not compile program , Failed attached log file
2- I don't know if data are sent to UART and there is no data in console, is it normal ?
3- Data sent and can be compiled
Could you check point 1 and 2 please
Another point without link with this
C:/esp-idf/components/esp_event/include/esp_event_loop.h:2:2: warning: #warning "esp_event_loop.h is deprecated, please include esp_event.h instead" [-Wcpp]
thx
send to UARTV01.fcfx
(10.78 KiB) Downloaded 444 times
send to UARTV01.msg.txt
(16.3 KiB) Downloaded 520 times
Seb
Xbiotec
Post by Xbiotec »
There is also many error message during compilation of my project
see the file
WifiV3.2.msg.txt
(61.41 KiB) Downloaded 500 times
Seb
LeighM
Has thanked: 103 times
Been thanked: 302 times
Post by LeighM »
re your first post - you need to remove the final \ character in send string
re second post - I don't see any errors, the compile and flash to device looks like it all worked ok
There are quite a few warnings, but these are normal (for now) and can be ignored.
Xbiotec
Post by Xbiotec »
LeighM wrote:
Thu Dec 02, 2021 3:32 pm
Yes you are right !
Yes without final \ character in send string, no error.
Thx
Seb
