Q about setPos
WingNut
Has thanked: 56 times
Been thanked: 43 times
Q about setPos
Post by WingNut »
I want to write a number to the very first bytes of a file. The size of the number isn't important but won't be more than ten digits.
What is the handle? Is the address 0? and is the 'from' also 0?
WingNut
Re: Q about setPos
Post by WingNut »
Go on give me a clue
Has thanked: 245 times
Been thanked: 257 times
Re: Q about setPos
Hi WingNut
a simple way is with append
WingNut
Re: Q about setPos
Post by WingNut »
Thanks Stefan. I want to add data to specifically the first bytes of the file. Sort of the write equivalent of ReadStringFromFile
Has thanked: 634 times
Been thanked: 842 times
Re: Q about setPos
I'm assuming you're using the FAT or FILE component and not the Simulation API.
Open file reads the first 512 byte sector of the file into ram.
Read Byte from buffer reads directly from the ram buffer, so you can read bytes 0 to 9 to get the first 10 characters of the file. Stores these into a string variable str[0] to str[9] and add a null termination at str[10].
OpenFile("File.txt")
idx = 0
while (idx < 10)
  str[idx] = ReadByteFromBuffer(idx)
  idx = idx + 1
str[idx] = 0
Then convert str to an long.
long = StringToInt$(Str)
Then do what you need to the long variable, e.g. add one and convert back into an string.
str = ToString$(long)
You may need to padd the string with leading 0's or spaces to get it back to the right length.
while (Length$(str) < 10)
  tempstr = "0" + str
  str = tempstr
Write byte to buffer allows you to write directly to the ram buffer so you can write bytes 0 to 9 from the string to set the first 10 characters of the file.
idx = 0
while (idx < 10)
  WriteByteToBuffer(idx, str[idx])
  idx = idx + 1
str[idx] = 0
WriteFileSector()
Write file sector then writes the ram buffer back to the file.
Hope this helps, let us know how you're getting on.
WingNut
Re: Q about setPos
Post by WingNut »
Thanks Ben. I'll give that a go when I get another 2 issues sorted :o
WingNut
Re: Q about setPos
Post by WingNut »
So before I get into saving data to the card. Can anyone help with compiler errors I'm now getting. File attached
Flowcode1.msg.txt
(3.15 KiB) Downloaded 1084 times
WingNut
Re: Q about setPos
Post by WingNut »
Update : I took out a goto component and put it back in exactly as it was and now it compiles! ;)
WingNut
Re: Q about setPos
Post by WingNut »
Hi Ben. So although i know c programming (somewhat) I'm not sure how to use this in flowcode. Is there tutorial available? I've looked and can't find anything with detail. I clearly cant just copy this and put it into a c code macro. Can variables declared in flowcode be accessed directly from a piece of c code or do they need to be declared in the block? Can you explain using your example?
Cheers
N
WingNut
Re: Q about setPos
Post by WingNut »
Hi again Ben. The attached is what i understand but i know it doesn't work. Can you give me a pointer?
