uart interrupt avr
d820513
Has thanked: 2 times
Been thanked: 1 time
uart interrupt avr
Post by d820513 »
Hi guys! why flowcode 9 does not work interrupt on UART avr microcontroller?
Has thanked: 698 times
Been thanked: 768 times
Re: uart interrupt avr
Hi.
I have just tested the ATmega328P with UART0 RX and the interrupt is working as expected.
For make sure the one-second flasher test works as expected.
Have you tested UART is set up correctly by seeing chars and checking they are as expected?
It makes a difference where the RXINT interrupt is placed.
For example, the interrupt will only work if its placed after the UART Initialise and not before.
If your Flowchart is still not working, then can you post it and I will see if I can spot any issues.
d820513
Post by d820513 »
Thank you. I will now post an example, I am trying to receive data from sim800l, and unfortunately I can't get interrupted
Uart_exp1.fcfx
(12.08 KiB) Downloaded 506 times
d820513
Post by d820513 »
baud rate on sim 800l 9600, as well as on the atmega328p controller, I do not understand what the problem is. I would be grateful if you showed how to properly organize the reception of data via UART
The attached works for me when I change it to my target.
If it does not work for you, then you have a hardware issue.
First, can you check your components are up to date?
Try the second flash as suggested.
Send a character and make sure it's shown correctly in your terminal software.
If it's not then the hardware clock speed does not match the clock speed of your configuration settings.
Uart_exp v2.fcfx
(12.44 KiB) Downloaded 545 times
d820513
Post by d820513 »
yes I checked everything, this option works without interruption.
I do not understand what's the matter
Uart_exp2.fcfx
(12.09 KiB) Downloaded 621 times
What about trying with the version I have uploaded?
d820513
Post by d820513 »
what version are you talking about? did I miss something
The version on this post.
Uart_exp v2.fcfx
d820513
Post by d820513 »
unfortunately the interrupt does not work for me :(
