Great. Thanks for all of you responses. There really are a lot of options and mostly the chinese companies are cheapest. There are also a few offering very cheap introductory offers. In my mind as a hobbyist the cost per single pcb is not that relevant as individually that makes it more expensive. However there would be little more satisfying than to have a circuit designed built and programmed and assembled on a professionally made pcb with stencilling and ultimately thats my goal.
"I made that"
After months of research and building multiple circuits using other peoples code, be it via ccs compiler or xc8 I have returned to flowcode and the pace of progress is immensely satisfying but quite a learning curve. What I have learned so far is so easily transferrable to other platforms and circuits and I thank everyone for their help.
Keep up the good work and helpful support
PCB services
WingNut
- Has thanked: 47 times
- Been thanked: 37 times
kersing
- Has thanked: 81 times
- Been thanked: 65 times
Re: PCB services
Keep in mind if you start creating boards for sale/distribution that there are a lot of regulations you might need to take into account. ROHS, CE, e-waste recycling and a lot more.
