Add variable in html ESP32
MJU20
Has thanked: 105 times
Been thanked: 74 times
Post by MJU20 »
Fast question: how do I get a variable into a HTML file in Flowcode?
I did that ones in FC, in a wired module but can't find the file anymore.
Any directions to an example?
I want to add a temperature into a HTML-file..
Thanks.
Has thanked: 221 times
Been thanked: 239 times
Re: Add variable in html ESP32
Hi MJU20
You can use the %1.....%10 to set in the HTML Code
Maybe this two sample help
viewtopic.php?f=9&t=739
viewtopic.php?f=4&t=761
<html>
<body>
<h1>Flowcode App Developer Webserver</h1>
LED is %0
<br />
 <form action="/page2.htm">
  <input type="checkbox" id="0" name="0" value="ON" %1 >
  <label for="0"> LED Control</label><br>
  <input type="submit" value="Submit">
</form>
</body>
</html>
MJU20
Post by MJU20 »
YES!! That was what I was looking for!
Thank you stefan.erni.
Too bad I can't read the example files.
I don't have the app develop tools..
Do I need to name the variable in FC %0?
Has thanked: 258 times
Been thanked: 414 times
Attached is one of those projects saved as a .fcfx file. It might not work in this form, but at least you should be able to load it and see what is happening.
The WebServer component allows you to change the values of the %1 (etc) substitution variables using the macro "SetOutValue".
AppDev_Webserver_LED.fcfx
(16.73 KiB) Downloaded 475 times
MJU20
Post by MJU20 »
Thank you Steve,
I will examine it.
The "Indicator" can be replaced by a common LED I guess.
