Print new number on screen and removing previous characters
Xbiotec
Has thanked: 37 times
Been thanked: 27 times
Post by Xbiotec »
hi,
On ESP32 TTGO like below to print number or text, the the printing start at de defined position X and Y. (start to print from left)
when print a number, it could be good to justify it a right and clear the previous characters. May be there is way ?
I tried these 2 ways but not good and difficult to manage well the offset and can not remove the previous first digit!
1- do not use offset , the problem is that numbers are printed from left to right and previous last digit still on display
screen 2.jpg (23.14 KiB) Viewed 5649 times
2- Print of 9999 in green at X and Y position then print 999 in orange at X+offset and Y position. Previous fist digit "9" in green is still on the display too
screen 1.jpg (20.48 KiB) Viewed 5649 times
Do you have a way to solve that? ( cleardisplay is not nice)
thx for your prompt reply
Seb
LeighM
Has thanked: 103 times
Been thanked: 302 times
Re: Print new number on screen and removing previous characters
Post by LeighM »
Add a space character to the text string.
You might need to do that based on the string length.
Has thanked: 234 times
Been thanked: 252 times
Hi lucibel
I wrote a macro for leading space or leading zero in the AppDevelopper.
As a suggestion for number of char: (3)for byte, (5)for uinteger, (6)for sinteger, (10)for ulong, (11)for slong
Maybe it help a little
String_leading_space._post_1.fcsx
(12.85 KiB) Downloaded 489 times
Has thanked: 724 times
Been thanked: 783 times
If you would like to post your flowchart, I can add a couple of examples for you.
Xbiotec
Post by Xbiotec »
Hi my data are currently numbers right now.
LeighM wrote:
Thu Dec 23, 2021 4:48 pm
So I used ToString$ then checked if number is more or less than 999 .
if more than 999 then add a space to the string.
It work well and was easy to do.
Thx LeighM
Seb
Xbiotec
Post by Xbiotec »
I can not send you the complete one who include EEPROM,webserver, networkcom,WLAN, 2 circularbuffers, 2 UARTS, RTC...
So I will send you a simple flowchart.
medelec35 wrote:
Thu Dec 23, 2021 11:48 pm
Seb
Hi.
A simple flowchart just displaying the numbers will be fine.
